- Oct 14, 2004
- 5,001
70_Steve said:Actually doesn't sound too good to me. I like the idea of Grade5 or Grade8 hardware, instead of some Home Depot all-thread.
To remount the coil springs, position the lower cup and retainer, and start the two bolts about two or three threads. Place the coil spring over top of the retainer, and "screw" the coil spring underneath the retainer until it's in position. Then tighten the lower two bolts.
There an article in the Tech section on installing the upper spring retainer.
I Agree. That's exactly how I did mine. I went from a stock coil to 3 1/2 inch coil and it still was easy. You just have to make sure you have the frame high enough so the axle can drop down enough.
