Sorry guys I wanted Brett & Bryan to help me with the responses and they've been a little busy... Here goes:
Cut Up 75: System T for 2500 include the front radius arms, coils, shocks, shock hoop? what else?
Its everything in the Monster Kit minus the leafs, u-bolts, shock mounts and shocks replaced by the 4 link kit.
Is there any way to run this kit with only 3.5" coils? Or would the truss hit for sure? I have a 2" body lift and really don't know about the 5.5" suspension. My rear end is really light right now, with only a 16 gal fuel cell, tool box and cage...Is the blue bronco pictured stretched at all?
Yes, you can mount the coil towers higher up to lower it to match the 3.5" coils up front. That is how Bryan's is right now and is stretched ONLY 2" in the front. We need to clarify that the ride height is adjusted by the installation of the coil towers. And the kit can be used for anywhere between 3.5-5.5" We are working on another set of coils for additional weight capacity.
onebadd73 How far back do you think you could have moved the rear end before hitting the gas tank? I just purchased my kit yesterday and would like to extend my wheelbase some?
Unfortunately it can only be moved back about an inch (like Crab did) without moving the crossmember. The crossmember is going to be the issue first. Also, what gas tank you are running as well.
Honorio Will the JD kit work on a full width rear axle?
Yes, it was actually designed on Bryan's full width but production for standard 9". (The center piece and gussets will need to be ground a little to work on full width.)
ugly74 As far as the website goes, the new one is still up (we added links to the ecommerce site on the old site) but it wasn't QUITE ready to go live. We are still madly adding things to the shopping cart! We also didn't want to lose all the info and customer's rigs that is on the old site. So we are running both sites for a while.
jeff Is this the pic you were asking about?
Keep the questions & comments coming! Let us know if we missed anything ;D
Suzy, Brett & Bryan
