Sheehanigans
Newbie
Hey all, long time lurker as I've been learning more about the early broncos. Finally got one and I've been scratching my head over some motor noises.
The truck is a 68 and I am told the motor is a 302 from a 72. It has a two barrel holley on top that had lots of black soot residue on it and the inside of the air cleaner. I have since cleaned it and it hasn't come back as bad, so maybe not a problem now. Or maybe an indication of another problem.
I changed the spark plugs and fluids, and immediately cylinder 4 is covered in dry black carbon. The wet oil on the threads are from running the motor without the valve covers so it dribbled a little.
At idle and increasing with engine speed, there is a tick that sounds like valve tapping. I have been researching and tried to perform a valve adjustment yesterday, but once I took the covers off I had second thoughts about what kind of adjustment I needed to do. The rockers are linked in pairs with a u channel guide, and that means that this is a 78 or later, correct? Non adjustable rockers? Just torque and go? What do I have here?
Also, exhaust is separated by each cylinder bank. On this side where the noise is coming form, holding a piece of paper up to the exhaust tip sucks the paper toward the exhaust every once in a while. A friend says that means a burnt valve? What do yall think about that?
Thanks!
Spark plug 4
3
2
Other side, plug #5
Any help is greatly appreciated!
Thanks!
Spark plug 4
3
2
Other side, plug #5
