1: 67-73 T-shift transfer case shifter
2: unknown. Aftermarket part? looks like it goes with #5
3: unknown. might not even be a car part
4: stated above, in the door (I didn't know myself)
5: unknown. Might go with #2
6: battery hold down rod (generic low cost aftermarket)
7: park brake adjuster
8: clutch pull rod (pedal, through floor, to equalizer)
9: park brake equalizer (where one cable is converted to a 2 cable pull)
10: 3-speed manual column shift reverse switch
11: garbage, but was part of an aftermarket cruise control
12: I want to say part of the park brake, but can't place the exact location
13: engine side bracket for the clutch equalizer. The middle bolt goes to the engine block unless you have a late model engine that doesn't have that bolt hole. The far hole bolts to the bellhousing.
14: looks like an aftermarket brake light switch, or reverse light switch, not really sure
15: I've seen it before, can't think of it. From above, got it. The friction preload on the vent window.
16: I just can't tell from the pictures. Looks like Paul got it at a liscene plate part
