The OE fuel line was 5/16" steel tubing. You can't do much to improve on it, except to use a filter with a '80s type double flare 5/16" inlet to avoid the rubber hose Ford used in the '60s and '70s. The hoses were the cause of many engine fires.
I used 3/8" hard line "sticks"--I found the copper-colored ones (some special alloy) at Carquest to be easier to bend than the painted steel sticks at O'Reilly...
