- Oct 11, 2022
- 369
I want to get rid of the rubber fuel line in the engine compartment. A PO cut the steel tubing about half-way, leaving a vertical post, then connected a rubber line with a Fram plastic fuel filter in the middle then on to the Holley Carb.
I considered going back to stock replacement steel but didn't want even the short rubber hose section, so I am thinking:
This connection from the existing steel line: https://www.amazon.com/dp/B098NNRVPZ/?tag=classicbroncos-20
This PTFE hose kit: https://www.amazon.com/dp/B07JFPXHB2/?tag=classicbroncos-20
This replacement for the banjo inlet on the Holley: https://www.holley.com/products/plu...fuel_injection_adapters/banjo/parts/977666ERL
So it would be all 5/16" line and 6AN fittings.
Should I install an in-line filter as well? I don't have anything but (presumably) the sock on the pickup in the tank and the Fram in-line in the engine compartment...
