New Core support angle??
Crazyhorse1977
Clovis Ca.
Anyone have the vertical angle of the core support or what it should be? I’ve heard it’s less than 90 leaning inward towards the engine at the top. Measured mine from upper cowl wall to top back edge of core support and passenger side sat at 35 5/8. The driver side which was smashed at one point years ago and pulled out was at 35 even. Im test fitting the new driver inner fender apron and core support so any help would be appreciated!
Rightpace
My top core support to firewall is 34 3/4.
I don't have a angle finder, sorry.
But if you bolt the body mount bracket to the frame, that bracket angle would be the same.
Crazyhorse1977
Crazyhorse1977
Clovis Ca.
Thanks for the info! The new support doesn’t come with the body mount brackets so I have to find the angle and tack it. Little massaging here and there is what it’s going to take to get everything where i can tack it in place.
suckerpunched
When I rebuilt the front clip on mine. a put the fenders hood and grill on. with core support stuck in there and inner fender aprons bolted to the fenders. Once all the exterior sheet metal fit, I tacked the inner panel together.
Crazyhorse1977
Crazyhorse1977
Clovis Ca.
That’s what I’m going to try now, I fitted the core and aprons up and squared the best I could, screwed in place and now I’m going to attach the fenders and grill. Crossing my fingers. Thanks for the info!
EricLar80
From doing this myself, I think the most important thing to get right is the angle of the inner fenders coming off from the firewall. If that angle isn't correct, the fenders will not fit up correctly. Everything else kinda falls into place when you clamp it all together.
