What is the minimum firewall clearance I should have on the driver's side?
I dropped the new 351W/AOD in yesterday and I'm looking at ~3/16" clearance from the drivers side head/valve cover to the firewall. I'm using WestCoast Broncos, Wild Horses Extreme motor mounts. No body lift but fresh body mount bushings. Prior to installing the motor mounts, I measured them vs. a stock type motor mount and it appears they are 3/8" higher than stock. I measured them because I had heard varying numbers in how much they raise the engine over stock. I'm thinking a stock type motor mount will improve the clearance at the firewall.....but I don't think it will be 3/8" for 3/8" improvement at the firewall......right?
Not only is the engine close to the firewall, it also looks like it will conflict with the wiring harness plugs coming from behind the fuse box thru the firewall right at the valve cover. Anyone else been down this road already and had to move these?
For the drivetrain end, I've got Tom's modified cross member. The frame brackets that came with the crossmember seem to have some forward/back rake to them that I don't remember the stock ones having.
