new leaf springs & roll bar
wesleydax
what are yals thoughts on leaf springs? i got a 3.5 lift now its 20ish years old. the rear is saging a small amount with out the top on. i read somewhere on here about 11 leaf springs and using 4.5" lift springs to level it out. i dont have a lot of stuff on it now but im going to add a few things.
second part: i only have a 4 point rollbar now, i want to ad the front part. who would you recommend getting it from.
Jeff76
Alpharetta GA
I just bought an 11pack from JBG (deaver) that's a 2.5 inch lift and it rides very well. Soft, but still firm enough to handle pretty well.
68Olblue
Auburn
I just installed some wild horses 3 1/2" leafs and coils. The rear isnlifted about 4" now because I don't have a top, spare tire, or gear in the back. It should level with the front when it's weighted down. I am very pleased with the springs, ride is great and flexes great too.
Ginzo
My 3.5" came from Wild Horses years ago. Back then, I had the option of 10 or 11 leaf packs. I chose the 10 and Rancho 9000's. Pulled a trailer nice, good ride. Then I built a HEAVY 8 point cage. The rear started to sag so I bought the 11th leaf. Everything was good until I ditched the heavy cage. I did the standard 4 point with the front cage (Tom's Bronco Parts) and also started running a bikini top. Now it rides plenty stiff in the summer (no weight) but works well with a trailer or in the winter with the top and ballast weight for my plow. BTW, with the top, it sets pretty level, without - tail high a little.
JSBX
Can't help with the springs but I bought a inside the half cab roll cage kit from Extreme Custom Fab a vendor on this sight. It was bent just right and tubing was longer then needed to make it easy to fit. Price was very good also.
wesleydax
wesleydax
for those of you that have eleven pack springs do you have any body roll? i was told today i needed 9 leaf. dont know which way to go. I very seldom run my full top, but i have a 35 for a spare with a bigger rear bumper and looking to ad a couple tools and stuff. which one do yal think.
