Finally put my one pc gasket on the 302.What a pain, you would think it should be a easy job WRONG!!! 7 HRS later finally done. If I have to do this again the stock pan is going back on, this 7 quart pan made it twice as hard, even with a 3.5 inch lift it was not high enough, had to hook my engine hoist to the front and lift it and it still was a pain, then track bar off, plus starter, and then exhaust had to came out. Started it up no leak so far I'll cross my fingers. Did find oil that is made for the older cams,made by Lucas oil.
