mini73
- Aug 12, 2013
- 969
Got a new stock power steering but found out the return line has a leak in the rubber part of the hose. What size is the rubber part of the return line hose? Want to get this today after work so I can keep working on the power steering. Tried running the belt on the new power steering pump after I installed it but it was leaking. I guess I also should flush it out then bleed it since I had the old pump off for awhile and power steering fluid came out of the lines every time it turned the steering wheel. Should've able to finish up the brakes this weekend and hopefully move the bronco out of the garage under its own power for the first time in I don't know how long!
