new rock blocker bumpers installed
SteveMa74
new WH rock blocker front and rear bumpers installed, plus winch.
Where should I put my hi-lift jack with this rear tire swing set up?
Also upgraded to the flaming river tilt steering column.
SteveMa74
SteveMa74
here's what the old bumpers used to look like.
JohnJohn
Richmond
Nice!
I got the same ones but with a few extra add on's. I should get them next week direct from Protofab.
I am also going to fab a Hi-lift mount when I get them.
TN1776
Looks nice! You almost have me convinced to finally buy a rear bumper to match my front...
Cobra11
West Hollywood, CA
looks awesome man...that changed the whole look of your truck! it was really nice before, but those definitely took it up a notch.
tcjones76
Tyngsboro, Ma
It looks like you have a bracket already on the tailgate, will that work for the hi-lift? My 48" jack is over the rear passenger tire, tucked up under the bed rail. A couple shock mounts from the HELP! section bolted to the inner quarter to hold it.
xcntrk
NOVA
Those look great! I've been in the market too and have had my eye on them. Glad to see some pics, looking good...
6daze
If the vertical portion of the swing arm has a threaded hole you can bolt your high lift there.
Set your jack horizontally on top the the threaded hole.
Center your jack and put a bolt and washer through one of the holes in the jack.
It think it is 1/2-20.
SC74
Huge improvement! Those are some very nice bumpers.
Bukin 67
Bronco Abuser
Looking real good. They're very clean line bumpers.
I have my hi-lift mounted on the inside of the tailgate. I welded 2 studs on the inside and bolted it on.
