Paul if the baffle u are talking about is the little metal plate that came with cover to stop splashing of the oil then mine is already fitted for one and has the holes and screws already there. All I would need is a rubber bushing to seal where the hose/metal end goes.
That's correct. And if yours is like the images above posted by someone else, that would work fine.
I was under the impression though that one cover did not even have a hole. Is that right?
If no hole, is there still a place specifically set aside for one to be drilled and the bosses for the screws are there as well? If so, you're practically in business.
But if none of that exists, and the baffle you got is for the one side that already has the hole/filler, then you're still back to square one.
Both openings would need baffles. Even the tall "stack" end where you fill the oil needs a baffle if it's only got a breather cap on it. If it's a stack with a sealed screw-on cap though, then the baffle is not as important.
Might still help though.
So yeah, when you get a chance post up some pictures, e-mail them to me (or anyone in this thread with a "contributor" status posted below their screen name) and we'll post them up.
Or, if you simply have a link to the parts you bought on some website we can look at them, that would save a lot of trouble too.
Are they on the World Products website?
