Its a 68 with the 6 cylinder. Im interested in keeping the truck fairly original. This truck is completely original (in fact it has the original tires on it). Some slight surface rust according to my friend.
that's a pretty cool find if it's accurate. Does your friend know all the little corners to check for rust, and all that kind of stuff?
I know the truck will only do 55mph with the original transmission and will probably update that.
Not the transmission only, but it's certainly one aspect.
If, for example, the truck has the optional 4.56 gearing in the differentials, and the stock tires are approx. 28-ish inches tall, then your engine is turning over at about 3000 rpm at 55 mph.
That's high, but not at the end of it's breath usually.
Now, if it just won't pull past 55, then it's not the transmission at all, but the weak engine running out of steam. Even a lowly 170ci six-cylinder should be able to rev past 3000 rpm I would think.
The owner wants $9000 for it. My question is, Ive read that you shouldnt bother with the 6 cylinder.
Well, Ford bothered with it, so my take on what you were reading is that those doing the talking don't like underpowered engines.
It's true, there wasn't much on tap with those things trying to lug around 3800lbs or so, but like was said, with you being by the beach and just wanting to tool around in the sun with the top off, it will get the job done.
But if you want to get on the freeway via that uphill onramp and people in your area drive 75 in the slow lane, you might re-think your options of keeping it original.
Even a six can be pumped up a bit, but it'll take more money to get it to a V8's neighborhood than just swapping in a V8 in the first place.
Im only interested in having a daily driver (i live near the beach) and would probably take the top off and cruise around as is. Thoughts?
Great rig for that! Tight turning radius, lousy gas mileage and a small gas tank(s) (but hey, it's only short distances, right?;D) and cool looking as all get out.
And an all original one too? Doesn't get much better than that. Except maybe a fully restored and updated one! But it's still cool.
You just definitely have to consider the power source, and the gearing. If that 55mph limit is just due to gearing, then larger tires or an overdrive transmission would get the job done nicely
Good luck!
