g8rb8t
- Feb 23, 2008
- 1,476
I'm about halfway through my Chevy disc conversion and had a few questions.
Probably dumb questions, but I'm learning.
From the picture I attached it appears that there should be a bearing race installed with each bearing (inner and outer). Do I reuse the stock bearing race or do I use the sleeve that came in the Timken bearing box. I don't think I use the timken sleeve as it's tapered on one side and square on the other and appears just for shipping.
Also does anything go between the outer wheel bearing and the first hub nut? I'm back of the stock hub it appeared to be a sleeve of some sort. I will be upgrading to Warn premium hubs if that makes a difference.
Someone set me straight please, thanks
Sent from my iPad using Tapatalk HD
