"Night Lighter" headlight relay wiring question
Waverous
Aurora, CO
I have an electrical gremlin I need help tracking down. I recently purchased a “Night Lighter” headlight harness from Wild Horses that I installed on my Bronco. Before installing the harness, I confirmed the headlights worked and switched between high and low beams. After installation, I tried the new setup and discovered I only had high beams. I researched the issue on CB and found a couple of suggestions that I tried out without success. I contacted WH, and they replaced my harness. I connected everything up with the new harness and tried the headlights again, and – no low beams again. An interesting observation is when I pull the headlight switch and try switching between high and low beams with the Night Lighter harness installed, I get low beams – click – high beams – click – high beams – click – high beams, and so on – low beams come on just once with the Night Lighter harness.
I have checked:
  • Grounds
  • Dimmer switch with a voltmeter
  • Relays with a voltmeter and switching them out
Any ideas?
Thanks, in advance
jerry
Bakersfield, CA
Chris ( @Waverous )
If your dimmer switch is like mine, it will benefit from a few treatments of contact cleaner. Mine was sticky / operated intermittently...
Look for something that cleans and lubricates, like:
https://www.guitarcenter.com/CAIG/DeoxIT-D-Series-Contact-Cleaner-Rejuvenator-with-Adjustable-Low-Med-High-Straw-1500000376175.gc
This works well on other switches / rheostats / potentiometers, too.
You could rule out a relay by swapping them, but I feel like it's in your dimmer switch. Let us know!
Jerry
jerry
Bakersfield, CA
Another idea: swap the relays in their sockets to rule the slight chance of another bad relay.
I bought the WH kit 10+ years ago, and installed a few months ago. No problems, very straight forward.
Waverous
Waverous
Aurora, CO
I did try that - no luck.
jerry
Bakersfield, CA
Here's another thought:
Pull dimmer switch. Jumper the plug, see if both high and low beams work.
Here's a Ford truck diagram as an example:
https://www.ford-trucks.com/forums/attachment.php?attachmentid=139546&stc=1&d=1457213182
With headlight switch on: use test light or voltmeter to find hot lead.
Then, with suitable gauge wire, jump from that to each of the other two terminals.
If this works: sure feels like the dimmer switch.
While you're goofing, I'd also double check the connector to the headlight switch. When I did my painless install, one of the terminals pulled out of the socket.
Jerry
Steve83
...the headlights worked and switched between high and low beams.
...with the Night Lighter harness installed, I get low beams – click – high beams – click – high beams – click – high beams, and so on – low beams come on just once with the Night Lighter harness.
Maybe just return the harness, and keep using the stock system that works.
Waverous
Waverous
Aurora, CO
Update
The issue has been resolved - I just rewired the harness, and now everything works fine.
Waverous
Waverous
Aurora, CO
After all the troubleshooting, I determined the issue wasn't the harness; the combination of the wiring harness I installed and some strange wiring gremlin that lives in the harness. Just to be clear, Wild Horses was great with their customer support - they exchanged my first harness and sent me a new one that was tested before shipping, so we knew it wasn't the harnesses. I decided to use some relays I had and rebuild the harness, removing one interesting piece included on the Night Lighter harness that neither Wild Horses nor myself could identify properly (picture below). I was also fixated on what I perceived as an issue with wiring into and out of the headlight socket - the wiring color didn't match across the socket connection - they were the same colors of wire in different positions on the socket. I've used mismatched wire colors when I wire something out of necessity or laziness, but I was sure Wild Horses didn't. so I switched them, knowing I would be sure of the current flow if I laid it out. So, with the rewiring and without that piece (switch/relay?) connecting the relays on my Bronco, I got the headlights to work properly.
If someone can tell me what this is, I would appreciate it.
