No Power No Crank
Okie69
So today was a happy day followed by some disappointment. I managed to get the new (to me) engine installed, but after getting everything ready I can't get it to fire. More specifically I can't get power to anything
When I turn the key to the on position (without trying to start it) I can hear the voltage regulator click. between positive on the battery and the ground above the voltage regulator I have 12V so that makes me think its not a grounding issue. nothing happens when I turn the key to the start position. no other lights work. I was getting a reading on the oil pressure gauge when I primed to oil pump so I guess that part is working.
If I attempt to turn the headlights on the relays (assumed aftermarket) will chatter but that's it. Relay chatter is usually a symptom of some type of common or ground issue, but I don't see where I'm missing it.
I've attached pictures of the starter solenoid because that, and the battery connections are really all I can see that could be causing it. I've got the negative side of the battery going to the block and the positive side going to the start solenoid.
Thanks in advance guys.
EPB72
Pleasant Hill, CA
If you jump power to the start signal post on the starter relay does the starter crank? battery fully charged?? battery terminals clean good connection??? add a ground inner fender from battery Neg post...?? but again will the starter crank by jumping the relay???
Okie69
Okie69
No crank jumping the relay. Battery is only reading 9.5v now it was 12.5 when I started. It’s an old battery it might be weak I’m going to go grab a new one in the morning.
I would still think something would at least try and move when I jumped the relay. Oh well, get a good battery and chase grounding problems tomorrow it looks like.
Okie69
Okie69
That did it! I added a ground to the frame and to the body in addition to the one on the block. Thanks for the suggestions.
