cbearly
BFPD630 said:Hey thanks- I had a great time.
Your box pulled away from the frame!? I did not notice what set up you have. I did not think that we did anything that could cause that type of damage. Could you put a few pics of that up too?
Yeah, I think it must have been starting to pull away before we hit the trail, and it just got much worse while we were on the trail. I had noticed that the steering seemed like it was starting to get a little bit of play in it before, but nothing like it was after running the trail.
I presure washed most of the gunk off of the frame this afternoon, and then got a closer look at it. It looks like it was welded before by one of the previous owners, but they didn't add any reinforcement.
Here are some pics from inside the frame and from directly below the box. You can see where the lower bolt closest to the cross member has pulled through on the inside of the frame, and in the pic directly below the box you can see where the frame has split on the outside lower seam.
