Not getting fuel to Carb
Banjer Picker
Hey gang,
So bronco won't start (unlessI dump gas in the carb). I pulled the fuel line going into the carb (right before the fuel filter). Had a friend turn the key and no gas is moving throught the line. I placed my finger over the end of the line and it feels like the (new) fuel pump is working or at least tring to. Where do I start looking for problems next?
If was thnking maybe trash in the line some where between the pump and tank, but how in the heck would I get that out?
Possibilities I've eliminated:
Empty gas tank
Clogged fuel filter
Faulty fuel pump
Any ideas?
Ben
concord
if the fuel line between the pump and the tank has a small hole it will suck air instead of gas try running reverse pressure through the line and see if it leaks
oleguy74
calif city ca
same thing both tanks?if so transfer valve ,main line cloged.just a note something i have done,reely dumb thing put fuel tank selector valve in between aux and main.this shuts off both tanks.
brian72
Early Bronco Student
just make sure all plumbing lines are set up correctly. I know I had mine cri-crossed...
77broncoguy
Grand Rapids, MI
I'd try running a line from your fuel pump inlet to a jerry can to see if it pumps that. Then you know your problem is between the pump and the tank. You can blow out the lines with air and drain the tank and flush it. If you have a metal tank you could be sucking rust and crap up the lines and clogging it if it gets low on fuel.
bax
Old Member
Take the line that goes to the pump from the tank off at the pump. Is there any gas coming out? If not take your gas cap off. This could help. Still no gas? Take a compressed air line and an air squirter wrap it in a cloth and put some compressed air into the gas tank. This will force the gas down the line and out line where it is disconnected at the pump. It may also force out any junk that is in the line. I use a rag around the air line because it will allow air to leak past and not let you over pressurize the tank. Quick and easy and works half the time. If no gas or air comes out you will have to start taking lines off until there is gas flow out of a line somewhere along all the connections.
Good luck.
Explorer
Raphine, Virginia
If it's been setting for a long time, float could be stuck closed or jets in carb could be clogged. I was getting ready to replace fuel pump till I checked the pressure and the jets were completely clogged.
