onebadd73
I recently rebuilt my NP 205 as part of my 4R70W swap. I put new bearings, seals and installed a set of JB Fab stainless steel shift rails. Yesterday I installed the twin sticks and its really hard to shift. I'm having trouble putting it in 2 high. I ended up removing the twin sticks and reinstalled the OEM shift linkage that connects the two shift rails just to see if that worked better. Wedging a crow bar between the case and the OEM shift linkage I can put into the different gears. Is it supposed to be this hard since the case is still dry and its not bolted up with the Bronco on? I've read that NP 205's are hard to shift.
