jjjjjgrant
i am parting out a 78 f150 4x4 and have this granny 4 speed and np205 t case i was thinking about putting in my 71 Bronco, but i have decided to go with automatic. I do have the shifter for trans and transfer case. 500.00 for the pair. have other stuff off the f150 if you wanted to go full widths or need a steering box to convert for your early Bronco. I'm open for trades, I'm wanting for my Bronco: soft top, long radius arms, fiberglass scooped hood, 67-69 ford truck grill. I have these other parts:
*solid hood w/ the side stress cracks $175.00
*three speed from EB,with v8 t case adaper likely needs going through
$150.00
*9" complete rear end "full width" 31 spline, 4.10 geared, track lock $400.00
gears are pitted, but good for off road rig or street but likely will make
noise.
*9" rear and dana 44 Diffs, front has disc. 3.50 geared, full width $650.00
for the pair, rear is track lock.
* running 302 engine w/ C6 auto $500.00 for both
* f150 4x4 spring towers (about 2" taller than EB) good for running taller
springs for less lift and more flex, also the longer shock brackets $100.00
* 302 engine w/ np435 4 speed, $500.00 for both
* f150 4x4 steering box to make your own 4x4x2 box for your EB $250.00
* steering columns from 73-79 ford trucks, auto and manual
I'm parting out several 73-79 ford trucks, I have just listed the parts commonly swapped to EB. I also have a few project trucks for sell. 2 crew cabs, short bed 2wd and others.
prefer local pick up. call/text 404-732-6550
$150.00
noise.
