Do your research had people on here tell me not to use the dana 20 broken gears cases and you need to upgrade the out put shaft . About to put black box behind a zf but with a 205 . Had both t-case wanted to use the dana 20 cause about 2.5" shorter . The 205 cannt break , longer , taller gears and the rear drive shaft is going to be fun .
