- Jul 31, 2001
- 8,986
Cutting the notch in the front of the NWMP tank back around '86 was the first time I modified it. I cut appr 3" down from the top, leading edge to allow the top to fit flat against the body and up almost flush with the rear crossmember.
Did it again to another NWMP tank when I installed a different body lift, then modified the tank again when I put 4 individual pickups in the corners of the tank, modified the same tank again when I stretched the rear axle back 7" and kept it at 22+gal capacity with a 4 link... all fits tight.
All I'm tryong to say- is do it right, do it the way you want!
Have fun, go wheeling...
