fatboy4211, your pictures look like mine. It has two holes all the way through the tank. The long bolts in your picture go through the drivers floor (with the big fender washers first) and through the tank, Mine doesn't have the "J" bolts and flanges on the front and back, like JefeAZ's pics.
I just used a floor jack to postion the tank, taped a sharpie to a dowl and marked the underside of the floor, with the tank in position. I removed the drivers seat and drilled the holes. Put the bolts and washers in and jacked up the tank and bolted it on. I used the same filler hose, vent tube, and supplie line as I had with the stock aux tank.
Been doing well since the early 90's. Since I now have EFI and a 32 gal main tank, I use it instead of Gerry cans on long trips. I have a cheap electric pump that turns on with the tank selector switch on the dash to pump it into the main tank.
I don't remember mine coming with instructions either.
