Nylint Bronco R/C conversion
eBronc2
Not so much a "conversion", more of a "put a Nylint Bronco body on a modified R/C chassis", but it was a fun little project.
I'm a bit of a collector, and enjoy R/C trucks, so when I found this original "Fire Chief" Nylint Bronco at a garage sale, I set about finding a way to convert it to R/C without losing it's cool patina. There are several cheap Chinese 4x4 R/C trucks on eBay, I got one that was $30 ready to run. Just basic controls (proportional speed, but only full left or full right steering), but a good size, 4 link suspension, and actual driveshafts.
The wheelbase was a little long for the Bronco, so I moved the rear axle forward a few millimeters, shortened the driveshafts, and converted the stock internal spring shocks to coilovers with higher rate springs to support the metal body. The interior floor and rear wheel tubs I fabricated from flat lexan, sprayed with black Rustoleum Texture paint to resemble bedliner. The shifter is actually an old worn out Dremel bit. I moved the tie rod to the top of the steering arms and used an adjustable servo link with a ball socket at the passenger knuckle to replicate my full size setup.
I kept the body as it was, except for removing the cross brace behind the seats.
It's not fast - the motor is small and low geared, and the metal body is much heavier than the plastic body that came with the chassis - but it's fun to chase the dog around the house. The stiffer springs reduce the articulation some, but it's OK.
svastano
Pulaski, PA
You didn't do it if there are no photos to prove it..... LOL Really I would love to see it!
FordBronc
Polk County, Missouri
The grandson just HAD to have "The Bronco one the Bronco one! And we will run over jeep one with it."
A while back I found an old slot car track rig (of mine from WAY back) that was a blue EB with a silver baja style roof.
https://slotcarcollectibles.homestead.com/AFXforSALE.html
eBronc2
eBronc2
I thought so too. It looks like a real one.
Nylint did a pretty good job when they stamped the body, faithful to an uncut EB. The grill is not quite right, but they have made it that way for copyright reasons. I kept the patina because old stuff earns it the hard way. The R/C chassis isn't really high quality R/C, more of a "toy" grade, but it looks OK and has some good features.
I'm still working on a roll cage and rear bumper/spare tire holder. Maybe some LED lights.
eBronc2
eBronc2
Got the cage done, used 1/4" aluminum rod. Measured, marked, clamped it in my vise, and bent it by slipping the tube handle of my engine hoist over the rod as a long lever. Worked like a charm. Coped the ends with a skinny Dremel abrasive roll.
