OBDII Reader/Scanner
ShoeSlinger
Any recommendations for a cost effective OBDII reader/scanner? I am doing an Explorer sway so I won't be using it very often. Thanks!
garberz
Bronco Influencer
Conejo Valley, Ca.
I use an ELM 327 along with the FORScan App. I used it in 2014 when I first did the install, and haven’t used it since.
Mark
904Bronco
San Martin, CA
Mark
I use the same... Garry has chimed in when I shared access to my Pad, checking numbers on Forscan... Works slick, don't use it that often.
I have a $35.00 OTC OBDII unit that I can use too.
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Scangauge is pretty good as well. Lets you pull codes and live stream data as you drive
Sent from my SM-G981V using Tapatalk
