Ocbr 2018
NYLES
Good to hear. Mine was kinda the opposite. Pedal moved about an inch or two and hard three inches from the floor. Last night it went nearly to the floor before getting hard.
Did you really jus say that?????????
NYLES
Ok jus fer you rocker arm ratio increase to 1.7 yes it increases lift but does it increase duration?
Boss Hugg
How will it act on rpm range and idle quality?
Can't tell you that. never used them. I'd think it'd wake it up but Idle should be fine. And check clearance with push rod guides and stuff. That added length on the arm can make the push rods rub on stuff.
NYLES
.475 cam to .505 bigger lift same duration should mean low rpm tq? see what howard cams suggests first
Boss Hugg
you seen the cuts in these pistones?
no. start a build thread. Tear it all down and start over. Show a pic for every bolt torqued. ;D Because all this has nothing to do with OCBR '18 or '19.;D
sprdv1
REBEL
That's alright... Long as gets what he needs...
