Oh boy, not again - 77 Build
rguest3
So, this showed up this morning. A buddy of mine found this solid 77 in Texas, and after finding out I am a sucker for a 77 Early Bronco he got it and brought it over. Yes, I purchased another Bronco. Thanks Jeremy.
Marti Report tells me:
1977 Wagon
Feb 77 Build
Copper Metallic
302, 3-Speed
Non Power Disc Brakes
Power Steering
Passenger and Rear Parchment Seats
Chrome Bumpers
Tire Carrier
Houston DSO
As it is now.
Single Stage Red Pearl - It's ok. Presentable, but I'll give it a 6 out of 10.
Super Lift Front Coils and Shocks - 2", Very Stiff
Add-A-Leaf Rear Springs - More stiffness
3" Body Lift - With all the Mods to make that happen and that will be changed back to original.
Previous Owner Option Welded Bumpers Front and Rear - Yikes!
Front Floor boards have been covered with sheet metal.
Rest of Body is pretty solid with No other RUST at all. Engine needs a tune up. (old fuel?) Exhaust is shot.
First is to remove the side steps and Welded on bumpers. Lets see how long this takes.
I already have a complete 2 1/2" WH suspension lift waiting for the next Bronco, so I'll use it on this one. I will add a lower 2" Body Lift, Adjustable Trac Bar, Sway Bar and T-Rex arms up front.
The current tires and wheels went with the delivery guy, Jeremy, who will use them on his project.
Clutch is shot from too much tire (34s) and too little gear. (3.50)
305/70/17s and Slots will go on after the suspension is complete and Axles and Brakes are redone.
The list is already getting long, but I will do this one piece by piece as much as I can so I can still have a driver.
sprdv1
REBEL
Sir you have an addiction.. haha.. but really Congrats!!
Keep em in the fanatic family. Can't blame you for picking up that one
nice score
R
rguest3
I have not removed the bumpers yet but the rear bumper will not be bad at all to remove. The front Frame Horns are toast and will have to be replaced once the front bumper is removed. The side steps will be removed next and then a lower 2" Body lift can be installed.
R
rguest3
She does call the Broncos "Cute" though......
But, yes, I am a lucky man.
R
rguest3
I got the welded on side steps and Rear Bumper removed yesterday. What a difference good blades and grinder wheels make. Some are just Junk.
Next is to lower the body lift from 3" down to 2". Then on to suspension.
Progress.
R
rguest3
The Exhaust will have to be removed next. Pipes are rubbing against the Suspension and touching the Transfer Case. It also has 1 Muffler with two inlets and two outlets. Kind of a dual exhaust, but I don't like it at all with pipes converging to the passenger side to the muffler, then going separate again out the back.
I'll redo the entire exhaust with a 2-into-1 with an exit out the passenger side at stock location. Probably go with a Flowmaster Super 50 or Gibson Superflow dual inlet/single outlet muffler. Both are quiet with a nice V8 rumble.
R
rguest3
Here is the exhaust that came off the 77. Other than rubbing the suspension and Transfer Case it also had a couple holes in the pipe, leaked at the Manifolds and a couple kinks in the bends.
Suspension Lift is next.
R
rguest3
I got the rear suspension installed on this Bronco today. Kinda nice to have the 3" body Lift still on it. There is a lot more room to do stuff underneath.
The new 2 1/2" springs added some additional height compared to the add-a-leafs that was on it before. I gave it a quick test drive and much better with the Bilstein shocks as well.
The Front end still has the stock rubber bushings with Rancho Springs. To say the least the front end is a little sloppy and stiff. Front suspension is next.
R
rguest3
I have the D44 removed and ready to be stripped, then have it rebuilt.
The front end on this Bronco was Very sloppy and did not feel stable to drive. It still had all of the original Rubber bushings in place. The C-Bushings were almost gone and the upper Trac Bar Bushing was also shot.
So, the rebuild includes replacement parts for the 1977 D44.
All new Bushings, Ball Joints, Seals and Bearings
4.56 Gears with LS Carrier
Adjustable Trac Bar and New Steering Linkage
New Bump Stops - None were present when I got the truck
Extended Axle Brake Line
Jeremybertolino
1977 Wagon
Feb 77 Build
Copper Metallic
302, 3-Speed
Power Steering
Chrome Bumpers
Tire Carrier
Houston DSO
As it is now.
I already have a complete 2 1/2" WH suspension lift waiting for the next Bronco, so I'll use it on this one. I will add a 1" Body Lift, Adjustable Trac Bar, Sway Bar and T-Rex arms up front.
Sorry I'm so late to this thread. Happy to help you out Raymond. You've done plenty for me too so I'm just happy I could reciprocate.
R
rguest3
Jeremy,
You need to start a build thread on your project as well. Lots of pictures are needed too.
R
rguest3
Suspension has been installed.
Original Master cylinder and brake lines have been removed.
New Brake system is next with rebuilt Disc up front and added Disc on the rear.
