hubdawg
- Feb 4, 2013
- 280
Have a 70 302 that leaves an oil puddle every time I drive (not the rear main)so I pulled the pan and found a new one piece rubber gasket. The problem I see is the pan at both ends has a raised ridge and the gasket is smooth thus creating the leak. I looked at a new cork gasket that had separate end pieces and they were the same smooth back. Is this a special pan ?
