Old School add a leafs
ep67bro
Bronco Junky
Easton, MD
I am working on my wifes 73. It has an old school duff 2.5" lift kit. It has 2.5" coils in front and add a leafs in the back. My question is where should the add a leaf go in the spring pack? This truck has the add a leaf under the overload spring? I thought it should be between the over load and the bottom spring. This add a leaf is heavy and not like the newer softer riding ones. I am replacing the spring packs and need to install the add a leaf in my new/used pack. Any feed back?
ep67bro
ep67bro
Bronco Junky
Easton, MD
I would love to get new springs but is not an option. I have no money to spend on this truck I am using what I have laying around to fix it! Just need someone to confirm the add a leaf goes between the overload and the standard springs!
Slim
Costa Mesa
Why are you going to use the add a leaf? Just for the extra height? Dont use the add a leafs and use a set of theses. Much better and not much money. Best way to get an extra 1" in clearence.
http://diy4x.com/cart/index.php?route=product/product&path=24&product_id=128
DIY4X has great products and even better customer service.
ep67bro
ep67bro
Bronco Junky
Easton, MD
Terkish Thats what I needed to know I thought they were installed wrong by the PO but just wanted to make sure. Two of the leafs were broken in this pack and the add a leaf was installed wrong!! No wonder the truck sat low and rode like crap! I wonder what I will find on the other side!!
And to everyone else I know Add a Leafs are not the best way but it is what I have and wont cost me a dime. Already got one spring pack back together. I will do the other next week and get this bucket of bolts back on the road!!
Good thing you're getting that squared away ep. I've seen quite a few add-a-leaf kits installed that way. I know how people think sometimes, but not sure what logic they use to try to squeeze that thick overload leaf into an arc, and why they don't notice that it's not doing the job the minute they start to put it together that way.
Add-a-leaves are a perfectly viable option. Maybe not "the best", but certainly not "the worst" either. Everything in it's place.
Hopefully the time they spent smashed up against the overloads didn't clap out the add-a-leaves though. They may be ok, but don't be too surprised if you don't get the full amount of lift you expect.
Crossing fingers at this end anyway.
The longer the leaf, the better riding for the amount of lift. But even short ones can improve the performance and feel of a clapped out original spring pack.
When spring packs wear, they often take a set and wear into the adjacent leaf. This gives the lower leaf a notch to get locked into and takes a bit of push just to get them to slide out of the notch.
When that happens, they ride like crap. When you add a leaf that changes the arch of the pack, and therefore the position of each leaf end, you can actually improve the overall ride feel by reducing or eliminating the extra force it used to take to get the springs to slide on each other.
Sure, it's "stiffer" (because you added a leaf and more spring-rate), but it might actually work out to be less "harsh" in the ride department.
Seen it happen often enough.
Maybe you'll get lucky and your wife will actually like the new road-manners. Lots of attaboy-points built into that project!
Good luck.
