ken75ranger said:
Here's my 2 cents.
Zip out side windows with the option to roll up. It just a couple of straps and snaps. It wouldn't add more more $.
That's a good idea that I hadn't thought of.
ken75ranger said:
Probably bestop's back window to tailgate attackment. STC's is terrible. Their old system was better.
Does someone have a close up of the current STC tailgate setup. I've heard conflicting opinions of it. What about don't you like. (Until a few weeks ago I had the Bestop on mine so I know how it is set up already)
ken75ranger said:
STC or a new style front riser to make the top come off easy.
Bestops do have the better door upright.
I was thinking about something different. Primaraily because neither riser really fits in well with my ideas.
ken75ranger said:
STC has the better window layout.
I think the Bestop side windows are actually better because the bar inside is positioned behind vinyl instead of the plastic. The side windows in the STC are larger though. Then again the Bestop rear window is larger.
ken75ranger said:
I do think the side window zipper flap is backwards though. The flap should go to the rear not the front.
The Bestop zippers are set up so the zippers are different on both sides. I.E. None of the zippers can be put together if the wrong side window is used. Not a big deal though. The zippers should be set up for the easiest access though. (Not sure how the STC zipper is though so I'm not sure exacty what is refered to above)
Looking over the responses above I already know I can't (reasonably) make everyone happy if I make one. If there needs to be a choice between function and fashion then function will be first.
A couple of items I saw mentioned above but that were not really specified too much were Durability and cost which are 2 that I think should be included. Cost isn't really a feature but it is a consideration.
Here is what I see listed above:
Choice of Colors
Durability
Quietness
Easy to Clean
Window Choices
Fabric Choices
Powder Coating
Installation without drilling holes
Zipper Quality
Easy to put up/take down
Removable Windows/Curtains
Roll up option for windows/curtains
Option to install a carrier/rack on top (200 Lbs.??? Is that enough?)
Cost
Looks??? (I'm lumping this into one since it isn't apparent what people want here. Some people like all of the available. Some people don't like all of them. No matter what someone isn't going to like the way it looks I imagine)
Quality compared to the Bestop??? (I was thinking of aiming higher than that)
Lower riser??? (Tradeoffs for both, can't make everyone happy)
Easy tailgate access
Snaps vs. Rails??? (Not sure which here was more desired, again there are tradeoffs)
Easy installation.
Convertible top style hold downs??? Still not clear on either what is desired here or how it would even be accomplished short of tossing money at it. (I refuse to take out a loan to develop something like this)
If I missed something let me know. Obviously there is no reasonable way to include everything listed so what are the most important things? Any others not listed?
Hotwheels, I hope you don't mind the way this thread has turned. If so let me know.
