addicted
Im just about done rebuilding my D20 J shift but I have a quick question. When I installed the front output, I put the spacer behind the front bearing like it shows in the on line catalog and WH breakdown. When I went to torque the flange nut, the flange bottomed out on the shaft. I took it apart again and double checked my work and everything looked good. Mine doesnt have the snap ring either. Put it back together and ran into the same problem. I dug through a box of parts I have for another case I'll be building and found 2 of the extra spacers?? So, I went ahead and put a spacer between the yoke and the bearing also and now everything seems good. Got my .006 front end play and everthing spins fine and seems to engage properly.
So what do you guys think? Just button it up and be done with it? I just dont understand why neither diagram shows the second spacer if its needed or how everything seems it working good if Im not supposed to have it. But I know for sure I have 2 J shift D20s tore down and 3 spacers so that extra one had to come from somewhere. And I'll just thank Viperwolf now for the info ;D
