smokinjoe
It's funny how a job with only two choices, so basically a 50/50 chance of getting it right, and it seems like 90% of the time it's wrong!
^^^^ AMEN TO THAT!!!!!! %)
OP, you say you can rev it while engaging the starter but as soon as the starter stops it don't run, right? Even though you've hooked up the coil directly to 12 volts.
You wouldn't be running an electric fuel pump, maybe wired into the ignition switch would you? (Just brainstorming)
