I'm looking for a 6 point roll cage and builder planned to put this one in. Does it seem a bit skimpy or will it get the job done if I flip my Bronco on the freeway?
Yes, that is weak. Triangular routing makes for strong cages.
Look at Federal Motor Vehicle Safety Standard 216 (FMVSS 216) THis is how new vehicles are judged for roll-over crash resistance. There is considerable force placed on the A-pillar during a highway rollover. Upwards of 4x the vehicle weight.
Looks like it needs some geometry. Remember, strength comes in angles. Add some bracing and you should be fine.
Bferrari - Who built your cage? I like that design.
That's a good starting point, but more triangulation would certainly help. I can't tell from the picture, but it looks like 2" tube, whereas others will generally use some combination of 2, 1.75, and 1.5 inch tubing. Wall thickness and material (DOM versus HREW) count for something as well.
As for holding up if you flip on the freeway, is that the level for which you're going to design your EB? Low-speed rollovers are one thing and high-speed rollovers are something completely different. If you really want to avoid ending up on your roof on the freeway, lower your rig's center of gravity and add sway bars and springs/shocks for street use, not off-road, otherwise everything is a compromise.
I made it. My build was so extensive, I needed a full Bronco model to understand how everything fit together. (It's still not quite done) Normally I share a lot of my work, but some of the CAD I'm hanging onto due to commercial potential I'm working on. I do have some parts of the model you can download at:Digger...did you create the 3D model of the body or download it from somewhere?? Any chance it is something you'd share? That would be super useful...
That roll cage is sweet. Did you build that?
My friend- you have talent!! This is really cool!
You want to build mor cages there Digger?
Triangulation is good but nodes are important too. Nodes are where the end of tubes meet other tubes and support each other. I'm not sure what all the fit constraints that marjama was designing under but I think these changes would improve the strength of the cage and remove a tube.
https://grabcad.com/digger-3/projects
