Original 73 door mirror ?
Fyrfighter115
ms
I am restoring a 73 bronco back to original or close to original as possible. I had the "power" mirrors (with the little handle on the door to adjust) on the truck and took them off for some unknown reason. I am looking to replace them with the same thing. Anybody know what other vehicles used the SAME door mirrors as the 73 Bronco?
thesnake
My 75 had the remote mirror from the factory on the driver side. They were pitted pretty bad. I found a replacement from a Mercury Grand Marquis. I've also noticed that some ford station wagons run with the same mirrors. I don't remember if the cable was the same length or not, but I do remember it worked. Hope this helps!
John
BwoncoHowie
C-4 Wizard
I have sen the mirror you speak of on 75-79 F-100s also. Mostly stepsides and shortbeds.
broncnaz
Try the mustang parts houses I believe some 67/68 mustangs came with the same remote mirror that the bronco had if its not exact its real close I've seen them in a national parts depot catalog pried from $50- $65
