I have a 1966 U13 that I am trying to get running. The fuel pump leaks at the diaphragm. I can't find a rebuild kit. As I was doing research, it appears that the original fuel pumps had the glass sediment bowl... Is this correct?
I have found a pump with the sediment bowl on the interweb, but wanted to make sure it would work okay. It has the lines for the vacuum operated wipers.
