Out west trip question
E
eb-nutt1
I don’t think I saw what your budget is, but have you considered a used Bronco Raptor? Lower-mileage ones are already in the mid-60s and trending down. If you’re looking at a new Bronco Badlands or Ranger Raptor, they’re going to be right in that same price range.
You are correct as I have been looking at used Braptors today and they are in the same range as a new SAS badlands
Scoop
Bronco Old Fart
Cuchara, CO
My suggestion is to get a used Badlands Sasquatch (for the sway bar disconnect), add 2-3 inch lift and maybe some additional skid plates, and you'll be good to go.
Agree with @Yeller, Raptors are too wide for many of the trails in Colorado. I've wheeled with a Braptor and a Gen6 on portals. Both had some problems. They made it OK but sure had some added pucker factor!
ntsqd
heratic car camper
Upper SoKA
Did somebody say “Rubicon?”
What is a steering rack? Sound like something found on a Prius?
Sometimes when I'm working on the Wagon(eer) I'm reminded that Jeep is a four letter word.
IME Prius are the second most common vehicle to see in the back country dirt roads of Death Valley NP. Subaru's are the first. When I mentioned this to a Prius driving, Son of Sacramento Delta farmers former Engineer co-worker he replied "Well of course! If you drove a POS like that would you care where you drove it?"
stout22
Athens, AL
I'm just past the point of dragging a bronco on a trailer 3k miles rd trip...I have a trailer and a f150, which the f150 needs replacement...kinda of the reason for the post, looking a trading the f150 for a dd/moderate wheeler.
I'm about to do the trip again. To me the trailer is peace of mind. If something goes wrong on the trails I can still get myself and my rig home.
Yeller
Rogers County Oklahoma
I’ve reached the point that being comfortable on the trails and highways are important. Without a trailer I figure I’m MacGyver enough to get home. I figure that applies to trailering or not, been doing a lot of both the last few years. Have also repaired plenty of trailers and tow rigs over the years.
jamesroney
Fremont, CA
Somebody PLEASE tell me that the Raptor / Sasquatch / whatever uses a front CV axle shaft that is bigger than the 1.25 x 29 spline in this pic. I read on the internet that the 6G runs a Spicer axle shaft that necks down to 1.17 inches??? That means that your 6G is using axle shafts that are SMALLER than your 28 spline EB rear shafts. There is NO way that they can survive with 35’s in the rocks. I sure hope I’m wrong.
jamesroney
Fremont, CA
Thanks for the link. I did read it. No meaningful data inside. Just Dana Spicer marketing garbage and ring gear size. The same morons that gave you a Dana 30 in the Early Bronco, the Dana 41, and Dana 53 in the Jeep, and the Dana 50 in the F250 are telling you how to build a 6G.
I looked at RockAuto, and it looks like the replacement axle is the same spline for all applications. But somehow 6G Broncos with 315/70/17 tires get a longer shaft? This is very disappointing.
1969
Reno, NV
https://bronco6g.com/forum/threads/front-differential-discussion.79723/
Some more info in this thread on the CV axles
Yeller
The Sas front diff is larger, CV’s are larger, but the shafts are still 29 spline like the non Sas, but are better, but still 29 spline……
IMO it needs to be 32 spline but I’m just a knuckle dragger that breaks stuff at the mall.
However for most users 29 spline is sufficient
jamesroney
Fremont, CA
Rant coming...
A statement that is mostly true, but often false is called "false."
An axle that is mostly sufficient, but often fails is called a "failure."
In the absence of alternatives, consumers are forced to endure failure. But the market rewards competition, and eventually the superior product will be adopted. This is why the Ford 9 inch has endured in passenger cars, and why the GM14 bolt endures in pickup trucks. When you are travelling across country to visit remote, rare and beautiful sites...you want enduring quality. Products with enduring quality become legendary.
Dana Spicer has done this now for so long it's not funny anymore. They constantly over-promise, and under-deliver. It just boggles my mind how they get away with perpetual engineering malfeasance, and they (the OEM's) never seem to learn. Changing the name of the product does not enhance performance. The M190 is a Dana 30 as we know it. The M210-M220 is the Dana 44 size. But as long as Dana is going to play games with the names...I'll try to use the important figure of merit. There are basically two. Ring gear nominal diameter, and axle shaft nominal diameter. Unfortunately, spline count is used as a proxy for shaft diameter, but as long as the splines conform to the same standards, we can correlate shaft diameter with spline. And I'm going to use inches, because the units are rational.
There are basic families of ring gear diameter in overhung hypoid gearing. 7-1/2, 8-1/2, 9-3/4, 10-1/2 These numbers correspond to torque and load capacities and are generally grouped together. 7.5 = Dana 30, 1/4 ton. 8.5=Dana 44, 1/2 ton. 9-3/4=Dana 60, 3/4 ton. 10.5=Dana 70, 1 ton. Typical rear axle shaft diameters go Dana 30, 1.25x27 spline. Dana 44, 1-5/16x30 spline. Dana 60, 1-5/16x30 spline, and Dana 70, 1-1/2 x 35 spline. (GM 14 bolt is 1-9/16x30 spline, and Ford 9 inch is 1-1/4 28 spline, or ~1-5/16 31 spline.)
Everybody on THIS site knows that the 1-1/4, 28 spline axle shaft is inadequate for a Bronco. I don't give a hoot that it's been 60 years, and there are still 28 spline shafts out there. AND I don't care that MOST people find 28 spline shafts "sufficient." Most people are WRONG. Everybody KNOWS that you want 31 spline shafts in your 9 inch. Which means you want 1-5/16 (actually 1.325") as a minimum for durability. Early Bronco folks know that if you want durability, you actually want 1-1/2 inch shafts.
Even Jeep (Rubicon JL, JT) has come to learn that you need bigger, and has compromised with the 1-3/8x32 spline shaft. My issue is that at scale, the 1-1/2 inch shaft COSTS the same as a 1-1/4 shaft.
The analogy I use is this: Most people could get by bolting on their wheels with just 3 lug nuts. 90% of people would find it "sufficient." So why don't you?
I am not interested in a purpose built, off road 4x4 that is "adequate" or "sufficient." I want legendary. And Dana Spicer stole that from Ford again.
Yeller
@jamesroney i agree, however it comes down to marketing, sales and what 98% of buyers find important, us 2% just have to have broken crap that we have to modify. Unfortunately most buyers want a legendary image, enough farkles to keep you distracted, pin your ears back from a stop light, oh and drive like a sport sedan. They could care less about legendary performance. If they did we would be able to by a Hilux with a diesel, manual transmission and a solid front axle, and for those that want more modern amenities a Ranger Super Duty.
Now back to the OP. Don’t over think it, find what makes you happy, comfortable and safe. Then GO and enjoy! I have been told by many that my rig isn’t built enough, this or that isn’t right, etc. some of our best trips out west have been just me and my Bride in a stock 3/4 ton diesel pickup exploring the back country.
kevscj5
Colorado
Not sure if i missed it or not, but to address the OP’s original question I’d suggest a Toyota 4Runner, 5th generation.
Comfy on the highway and can tackle some gnarly stuff. TRD Pro equipped, for starters, with a few more goodies and it’ll probably suit ya fine.
lars
Been here awhile
NorCal flatlands
It's a fuse, @jamesroney . Lol...
