oxygen sensor harness and pump fitting
CRZA1
Albuquerque
I am nearing the end of my EFI conversion (saga). One piece I am missing is the oxygen sensor harness. I have noticed a few things. First the harness for the mass air setup seems to be as mythical and hard to find as a jackalope. No junk yard or ebay parts to be had. I noticed that the mass air(ho) and SD setups use the same 3 wire sensors (same generic bosch part #'s). I also have seen several speed density setups (untouched) in the U-pull yard. The SD and MA oxygen harness plugs are the same shape and pin setup, and both use the 3 wire sensors. So can I interchange the two ?
Also I am using a frame mounted OE FI pump as my high pressure pump. Unfortunately I recieved the pump minus the high pressure side fitting. The treads unfortunately are not pipe thread rather 3/8-24nf (or so they seem) No fitting shop nor Home Depot havs anything that will work? Any sugestions as to where I might procure the proper fitting.
Any help would be appreciated.
Thank you
