Painless EFi and Centech chassis harnesses
Texanferever
I have a centech chassis harness installed, and has been working for 4 years without any problems. Now I am putting in a painless EFI harness, and I am not getting any power to the fuel pump. I have not tried to turn the motor over yet withour the fuel pump so not sure about that one.
I know the motor and computer worked in the 91 mustang it was pulled from just a month ago. I guess I am missing something but I just don't know where to start. I am getting 12v to both the EEC and fuel pump relays, but nothing is coming out of either relay, is there supposed to be power coming out of the relays with the key on?
The grounds have been checked and are good, what am I missing?
68stang73
You need a keyed ignition to activate the relays. It needs to be hot in the start and run position. I might be interested in the centech set up if it's in good shape still.??
T
Texanferever
The painless guy told me I need a constant 12v source, and there is only one power source wire from the painless EFI harness.
68stang73
A relay is like a light switch. Instead of your finger to flip it on it requires a switched ignition 12v to flip it on. One of the ports on that relay is the switched port.
T
Texanferever
got that figured out, I actually forgot the two power supply wires to the relays since it was ziptied to the test wires I just flat didn't see it.
