Just throwing this out there as I custom paint. If you step up with much better clear coat it will last a bunch longer. Mason clear IMO is about a 3-5 yr clear in full sun. Just giving you a heads up/ trick of trade.
No sorry never heard of that brand. Not saying it's bad at all. But if this is a rock bouncer/trail rig then it will be fine for sure. But if your doing a sweet DD that you just soaked a ton into then why cheap out on the clear coat? If you can look up the reviews on it and talk to your local pro paint supply store. Myself I use ppg products alot. On lower end stuff I'll use their omni base (mason) equivalent. But jump up to the good ppg clear.
I've had good luck with it. I redid a wagoneer and the body shop used this clear and it still looks wet to this day. But I'll def check out some other ones.
If it's holding up well and your confident in it then roll with it for sure. Just be sure to mix properly and recoat after it gases out well. I usually wait until I can finger drag. Just check on the mask. Good luck. I love painting. My last job was a victory motorcycle. The guy won every show last year. The last show of the year was over 300 Harleys and the victory walked away with 4 awards from that show. Surprisingly they let him ride away. Hahaha
