Painted Door Hinges?
AFLtCol
Is there any way to prevent the paint on freshly painted door hinges from rubbing off when you open/close the door? Do you just keep a little grease on the exposed metal afterwards? I'm considering going with the stainless hinges but read several thread about them not lining up correctly.
englewoodcowboy
Lick Creek Restorations
They are going to rub regardless at the hinge point. Most of the paint should stay on them other than the rub point. If you are concerned, I would do as you stated of putting a little grease on them. If they surface rust a little it will be rubbed off the next time the doors are opened etc. I annoy a fan of the stainless hinges. We disassemble the hinges and prep them for rebuild, drill and have them ready for new bushings then we send them out to be yellow ink plated (just as the factory did) which will put a protective coating where the contact points are, then we assemble them and paint them when we paint the tubs.
wsager
How do you prep them after the zinc plating?
KBUCK1
I painted my stainless hinges 4 yrs ago and cant see any ​paint missing. Doors line up as good as any bronco I've seen
