painting a bumper advice
77BroncoWag
what kind of paint(rattle-can) would you recommend for a bumper ??? Want something durable yet when it gets scratched off road or pushing that damn yota out of the way on I-5 :mad: I can touch it up easy enough.
FSRBIKER
Oak Ridge, NJ
Rustoleum Hammertone, very durable paint. Use some Rustoleum etching primer first, it says on the can for metal that has slight surface rust...it gives the paint something to bite to.
This is what I do for the rocksliders I make or POR15 first than use the Rustoleum Hammertone.
howiebilt
Bronco Buddah
Newton
I prefer the self etching primer and the duplicolor spray in bedliner . That stuff it tough enough to withstand rock rash :eek:
JaxLax
Jacksonville, FL
I'm cheap. 2 coats Duplicolor sealer/primer (after removing ALL surface rust) Then 3 coats white enamel, she shines like a champ and touch-ups are easy.
66horse
Another vote for duplicolor spray in bedliner. That is what my bumper and roll cage are painted with. Gives a real nice look and is tough. I got hit in the pep boys parking lot the other day. Dumb asshole just backed right into me. I mean the bronco is pretty big (sits on 35s), how could he not see me. Anyway is was fairly low speed, didnt damage the bronco, jacked up his trunk real bad though.
The point being that only a little bit of paint came off the bumper.
77BroncoWag
77BroncoWag
did you tell him it was a spenial coating for off road use so if he wanted to save some $$ to just pay your 250 dollar deductable and he'd never see you again 8)
66horse
[quote author=77BroncoWag link=board=5;threadid=16508;start=0#msg125795 date=1050686731]
[/quote]
No, I was pissed then saw no real damage, so calmed down real quick. But then the a-hole started yelling at me and asking why I didnt honk. Then he got an earful. It was sweet like three other people in the parking lot all said Ill be inside if you need a witness, we saw what happened. Then he got in his car and drove off. I thought about following him, but then just laughed at his damage compared to mine. Just chuckled, thought what a jackass, and then Iparked and went into Pep Boys.
BoltBuster
Is the bumper Chrome or use to be?
Your going to have to get that brought down to wear paint will stick to it, even if its been painted previously-
Its going to need to be Blasted off and then a product like POR15.
dupont variprime it is a acid type sealer It will work also, It will work also as I have been told when going to do mine-
Hnrys69
The duplicolor regular spray paint is holding up very well on mine :)
Wzbell
Troutman, NC
Duplicolor bedliner spray. Durible and you can touchup without noticable changes in color. Not as durable a line x or a real bedliner but close.
SteveL
Huge chevy guy
Hawthorne ca
that duplicolor is basically bumpy spraypaint. I use black rustoleum because it is the easiest thing to touch up.
KST1
I used Duplicolor Bedliner for a quicky paint job on my custom carrier and rack. It's not holding up to well. I didn't prime however so that's probably the problem ::)
-D
