bknbronco
I will be ready to paint my inner front clip (inner fenders, core support, support brackets, fender aprons, etc). All this is brand new steel.
I was thinking of wiping everything down, welding all the pieces together, wiping down again, and then painting.
1-Should i sand everything down before priming? I need to remove the bit of flash rust, and scuff the new bare steel. This would be hard because of all the nooks and crannies. Maybe it would be easyer to have it sandblasted?
2-Will the primer and paint bridge the seams? How do you keep water and rust from getting between the seams? due to capilary action, water would get sucked right in, even up hill. I have seen seam sealer that comes in a caulk tube, is that what i use. I know paint will not bridge seems very well, and would allow water in to the unpiainted metal.
3-For painting would you guys......
A-etch prime, seal, and paint (do i need to seal? What does that do?)
B-epoxy prime, and paint
The entire inner clip will be gloss black. My bro usually used Omni brand. should i go with a better paint like ppg? What brand goes on and stays on? Seems like his Omni paint jobs arent that durable (but if you crash your motorcycle every race it dont need to last that long anyway%))! Also he always wet sands between coats of primer and paint....does wet sanding all that not make for a good surface for the paint to adhere to? And he has never heard of sealer primer...is he missing a important step?
