Park brake cables
Stock drum brakes. I am finally getting the stock drum brake parking brakes to work. The last I remember was to use 2 passenger side park brake cables to keep the drivers side from limiting travel. Route them over the top of the spring to keep them out of harm. Is this still the way to go? I have 4 part store searches going right now and am looking at about $60 to get all the parking cables (providing I get matching passenger side cables). Just a 3½" lift.
Tito
CB Fire Starter
Bakersfield, CA
I remember but have not done it but to use extended passenger on pass and stock pass on driver.
So just 1 new cable needed if stock is in good enough shape.
OK, not what I remember. So start looking.
Stock LH 50-1/16"
Stock RH 60-1/2"
Stock 79 LH 58-1/4"
Stock 79 RH 76-3/8"
Now to confuse things a little more, the body side bracket for the parking brake is being located closer to the centerline of the Bronco to line up with the hand brake between the seats.
Guess it is time to dig out the jack, the jackstands and the tape measure. So I have the total length of the cables, I wonder how long the sheath is? That is what I will be measureing, but the published lengths are the full length tip to tip. If I can find just one set of numbers I can back calculate the installed length of the other options I find. Maybe I should just order one stock passenger side cable, measure it and figure if I can use 2 of those, or maybe mix and match other 70's truck park brake cables to get the length I want. It is never easy. I always have that one odd part that just keeps the normal fixes from being that normal.
TN1776
I would not trust original cables, it's a safety thing. My stock rear cables were nowhere near long enough so both got replaced with WH extended cables. Then after using the new extended cables with the stock cable that runs from the pedal to the junction, the stock main cable started failing. Just replace them all, protect them from chafing on anything, and dont' worry about them for years to come.
I just did static and droop measurements for the the cables. Due to the relocation of the body side bracket for the hand brake I will be using 58¼" cables on both sides.
The venders extended cables might be a good choice if things were a little more stock, But the floor mounted park brake and relocating the body side bracket changed things for me a lot more then I expected if would. The 50" cable is too short for the drivers side, but a 55" would be nice. 58" is close enough and happens to be what works out perfect for the passenger side. I found a 60½" cable off an 80's F150 in my scrap pile that I could use on the passenger side except the old cable is too froze up to release correctly.
robofig
I put a 3.5" lift on in 1991 and a set of 1978 e brake cables on in 1992. Still running them. No problems. I have added a couple of "slinky" type springs to keep them out of harms way, but that is it. To me, the way to go for the money.
