I'm packed and loaded for the Super Celebration so changing my delivery location.
email me for fastest response
I will delete the pictures & descriptions when they are sold..
I will only deliver parts the the MEB East Coast Bronco Roundup and they need to be paid for or a deposit put down to get them loaded for the trip.
I will not ship... don't ask...
here is a link to the pics.
https://plus.google.com/photos/1032...s/5741414040893370561?authkey=CK3Huo30m9zQlQE
Kayline soft top Black my bronco is always garaged, top has been on for about 8 years no rips, tears all hardware is included ( screws & bolts too) some is new as I put on a rampage top and reused some of the Kayline stuff, Top is modified so you do not have to drill the holes in the door jamb, bolts to the most forward hole from the hardtop $350
Headers stock 85 mustang 5.0L carb motor $25
C-4 Flex plate 164 tooth , I have a few $10 ea
Flywheel 3 speed $10
Coils pick one accel, jacobs, stock $5
Smog pump alt bracket I think $5
Plastic air intake Tube $5
Radiator lower 5.0L with stock rad crossover tube $10
Radiator guard $5
Mirror used has Ford numbers stamped in the bottom, Ok shape $10
Heater box $25
Rear bed mat has seen better days getting dry $5
Hydroboost bracket from the ebay guy was for a vacuum booster I cut it up to make it fit hydroboost I will include the parts I cut off needs welded $25
Tool box side tray new $10
Cooler came off a range rover about 30" long $5
10" electric fan $15
Truck mirrors $5 pair
Stock bronco Starters $5 have many
Window regulator Right Hand plus other door parts $10
Hardtop Liftgate Seal 1969-77 $10
http://broncograveyard.com/bronco/i-16049-hardtop-liftgate-seal-1969-77.html
76 manual master cylinder spacer $5
Brake pedal assembly $25
H pipe & cats from 92 mustang 5.0L 18K miles its been in my garage for 18 years $150
Bronco 3 speed clutch arm $5
Dick Cepek chrome wire cover $5
New Vent window lower pivot left I have 2 $10 ea
New Vent window lower pivot right I have 2 $10 ea
hydro boost angle bracket ( uses 90-95 astro booster) from the ebay guy $80
http://www.ebay.com/itm/early-bronc...ord-/161000326719?vxp=mtr&hash=item257c5e063f
pair of radius arms $20
Mustang 5.0L distributor rubber boot $5 ( I have 2 one is sold)
inner wheel tub $10
Material cart model PC472-P6 72" x 36" "google it" $200
Fan Spacer Stock Bronco $5
OTC Hub Tamer part number 6537 ( used for front wheel drive cars) only used a few times $275
http://www.otctools.com/products/hub_tamer_elite
Snap-On AC manifold set model number ACT51234A $100
Stock Bronco Gauge only 82K original miles $100
DAVCO model 380134 Fuel-Pro 380 and 382 Fuel Processor Collar Removal Wrench $5
OTC 1932 2-7/8" 6-point Wheel Bearing Locknut Socket $5
OTC-7028 Spicer Clutch Adjusting Wrench Heavy Duty OTC $10
Maverick ET-732 Replacement meat Probe I have 3 $10 each or $25 all 3
FORD ROTUNDA OTC TKIT-2007SP-FLM 303-1398 SPARK PLUG CERAMIC REMOVER 5.4L 3V ENG $150
this is for 2004 & up kit looks complete may have some extra parts too, not sure what come in the base kit.
this is new never used. $150
4 way flasher bracket $5
Thermostat housing I have 2 $5 each pick one
Jack Bracket $ 10
Quarter panel rods / brackets stiffeners have no idea what they are called $ 10 pair
Shock mounts stock rear just cut them off a '74 $5
Storage drawers made of wood 2 drawers 3 carpments in the drawers, size 19 w x 16 D x 10 h $10
Radiator guard $5
Heater box $25
inner wheel tub $10
Jack Bracket $ 10
