Mckinleyrb
- Sep 17, 2009
- 20
2250 - Fiberglass tub and one piece front end (new) - sold
250 - 6 point roll cage
70 - new windshield
125 - new windsheild frame for electric motors - sold
50 - Heater assembly with working motor and good heater core
300 - Original bronco PS box
50 - 3 spd hurst shifter with all new bushings - sold
100 - Powder coated dash with instrument cluster(radio hole modified for newer style radio) - sold
75 - Powder coated pedals and bracketry - sold
75 - power brake booster with bracket and master cylinder SOLD
250 - EFI setup off an 87 mustang (computer, distributer, harness, intake, injectors, EVERYTHING)
100 - tailgate in good condition with licence plate bracket - sold
50 - steel hood - some surface rust
1450 - chasis with all new brake parts (rotors, drums, pads, shoes, SS hoses, lines, dana 44 front an 9 inch rear. 3 spd trans, gas tank with sending unit, 4 inch bc broncos lift with coils, 11 pack leaf springs, front and rear adjustable track bars, tie rod over conversion, 302 with all new gaskets and freze plugs)
I dont want to separate the chasis parts because i dont have a garage where i live now.
Im in richmond VA
http://s571.photobucket.com/albums/ss153/mckinleyrb/
Ok, ive got some more now that i have done a full inventory
72 wiring harness (I belive it is complete except the wires that go to the sending unit and rear lights)
40 - new winshield ruber gasket and hinge gasket (no dryrot) - sold
10 - fan blades
50 each - 2 radiators (stock bronco)
30 - rebuildable holley carb 2 BBL, may or may not be stock, check pictures
20 - 9 ft of braided fuel line
20 - 15 ft 2awg wire. great for a batery relocation or runing dual batery setup
20 - licence plate mounting assy
15 ea - stock exhaust manifolds
50 per pair - stock front seats in good condition (1 black 1 white)
plastic ducts for heater and fresh air vents
30 - stock air intake
30 - another complete pedal assy. no bushings, a little surface rust
20 - E-brake pedal assy
25 - gas tank filler nozel assy
10 - stock pitman arm
20 - 4 nch drop pitman arm sold
20 - PS pump ( not sure what kind, but not stock)
20 - metal tailgate braces thingys?
75 ea - working wiper asemblys with motor
50 - 1972 instrument cluster
25 - light dimmer switch
50 - rear tire swing arm and mounts. no latch
40 - heater core and box. motor is shot, removed motor for lighter shiping weight
40 - new valves that mount to side of engine block for smog system, brand new and hard to find
15 - charcoal canister, plastic
Pics are on above link
70 - new windshield
Im in richmond VA
10 - fan blades
