DuneBuster
I've never had to do any Emissions work, but my setup is definitely putting too much gas in the engine oil, so I wan to install a PCV system.
As I recall, most production PCV systems hooked to a breather on the outside of the air filter, meaning low vacuum.
Can I run a PCV valve directly to a vacuum port on the Carb or is that too much vacuum? My current air filter system is a plate above and below the air cleaner so there is no place to connect a PCV breather to..
