Trying to hook up Pcv line to Carb, no vacuum lines. Can I go to this dpot on Intake
Justafordguy
I agree that there is nothing wrong with that intake for your setup. I have the same one on mine and it works great. I installed a 1" carb spacer that had a large vacuum port on the back for my PCV hose in place of that factory one with the EGR ports on it..
Also, I bet the reason your pictures don't always show right side up is that they are taken with an Apple phone. It's a common problem with I-Phones, just be sure to take the picture with the phone held horizontally and the shutter button on your right. ;)
B RON CO
Statesville, NC
Hi, read the posts from the guys with intake gasket trouble and aluminum intakes before you get rid of the Ford intake. I would stick with the Ford manifold. Good luck
Justafordguy
That is similar to the spacer I used and should work but the one I got didn't completely cover the Exhaust hole in the intake under the spacer. I filled in the hole in the intake with J-B weld epoxy so it didn't matter. Works great with that type of spacer now.
