- Joined
- Oct 25, 2016
- Messages
- 952
Nearing end of tear-down
Getting down to the bare frame. Coil springs, front axle housing and radius arms have been removed. Not much left of the coil cups and not sure if radius arms will be salvageable. I’ve learned that it’s best to get all the nuts and bolts loose prior to trying to raise the frame and remove the axle housings. I have a loaner slide hammer and soaking the rear axles to try to get them free prior to removing the rear end assembly. Once the rear assembly is removed, the frame should be ready for a chemical dip. Looking forward to attaching shiny parts.
