    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
KY Performance parts 302,331,347
Status
Not open for further replies.
Ourobos
Big Island Hawaii
I have a 331 that I am disassembling and detuning the car. All parts are off a fresh running vehicle unless specified new.
331 Stroker, E6 roller block, Keith Black forged inline pistons, 5140 cast crank and i-beam rods, arp main studded. Had new cam bearings when motor was built about 5000 miles ago, still in good usable shape. Balanced to 28oz. - $1250
Brand new DSS SX 347 short block. It is a stock block, clearanced for a 347, .030" over, new freeze plugs, cam bearings, rear main, and arp main bolts. The rotating assembly is from DSS, it' is their -3cc inline / twisted wedge pistons (11.0:1 with a 58cc head approx.), nodular iron crankshaft, and nodular iron i-beam rods. It has hasting moly iron rings, and clevite main and rod bearings. ARP wave lock rod bolts. Full floating pistons with double snap rings, bushed rods .912" pin. Main clearance ~.002", rod clearance ~.0015". All balanced to 28oz. Ready to start bolting your go fast pieces on. $1700
MSD 8456 TFI billet distributor - $175
75mm BBK Throttle body and 75mm spacer (no sensors) - $150
Tubular GT40 intake with 1" spacer and upper to lower hardware - $400
ARP head stud kit complete used once - $60
Holley 1.94" pedestal mount heads. Upgraded .600" lift double springs with dampeners. I will clean these up, they're fresh off the engine - $700
Second set Holley 1.94" pedstal mount heads. Single .550" springs with dampeners. Pick which set fits your cam better - $700
(2) Kirban Adj. Fuel Pressure regulator - $50
Pro-M chrome bullet 24# mass air meter and 24# injectors - $150
MGW T5/T45 Shifter and Handle - $125
Moroso 7qt pan, pick up tube and dipstick - $175
Scorpion 1.6 pedestal rockers complete - $175
Black TFS valve covers with oil tube - clears roller rockers - $90
Trick Flow Stage 1 cam - TFS51402000 - $125
Lunati cam .565" lift - http://www.lunatipower.com/Product.aspx?id=1663&gid=282 = $125
(2) Pro-5.0 shifters - one with handle one with out $90/$80
All prices picked up at 42101, will ship on your dime, normally the next day after payment. By quoting this long picture post, you confirm you are a moron.
Status
